Thank you for your reply Ill follow this instruction THXbed cap brake light:
tap into your driver side brake light. to do so, you need to remove the tail light and unplug the harness. Find the white w/ green wire (iirc it's white w/ green. it's been a long time since i last did mine and when i swapped from bed rack to camper i just cut and reconnect the third brake light) and use a t-tap to tap into it and route your cap's brake light. check if it works.
if it doesn't you'll need to use a multimeter to find the correct wire.
interior lights:
run power and ground from battery under the hood along the frame and up the holes in bed. connect the led strips to a switch and switch to the wires you just ran. Don't forget to use an inline fuse and zip tie the wires to the frame. i don't like to make it in conjunction with other functions (like turns on when you open the tailgate or doors, or etc) because that's limitation. What if I want to leave the lights on for extended period of time, after the door light times out? What if I want to turn on the lights but no need to open the tailgate?
alternatively, if you are planning for more electrical stuff in the bed (or doing a camper-living space type of build), follow my steps here:
In-depth View of Electrical System for Overlanding and Offroading
start from section called "camper system"
double check on the brake light wire with a multimeter.Thank you for your reply Ill follow this instruction THX
that looks a lot more involving than just t-tap the brake light harness lolllBelow is the wiring info Leer uses to determine wire tap-in location for CHMSL and locks. There should be an existing wire gromet below the rear drivers-side seat to run the wire through into the cab.
I'm pretty sure there is no spare wire in a bundle for this purpose like there was on the 4th gen trucks.
				 5thgenrams.com
					5thgenrams.com
				I have a 2019. I took my driver's side brake light out this morning hoping to see this cable but couldn't find it. Where should I be looking?This is the spare wire you'll find under there. I soldered to it for my 3rd brake light on Bestop supertop and works fine. And you can see the reason to not use a knife to take the tape off...
From underneath, driver's side near the back. It's raining right but but I'll try and get a wider view shotI have a 2019. I took my driver's side brake light out this morning hoping to see this cable but couldn't find it. Where should I be looking?
Look up above the outlet to the drivers side resonator. There is a large grey electrical connector. Follow the wires out of the connector towards the front. It'll enter another bundle of wires. It's here that the white and purple wire is wrapped in a few layers of tape. Mine is inside a loom in the photos but you can see a little bit of it at the arrow. Unwrap the tape to expose it. I didn't recall if you can see any sticking out. Maybe you can feel it under the tape.I have a 2019. I took my driver's side brake light out this morning hoping to see this cable but couldn't find it. Where should I be looking?
I appreciate it! I'll crawl up there tomorrow to see if its there. I have 2019 so, I'm not sure if they included the brake light wire. If it's not there where else can I tap? TIALook up above the outlet to the drivers side resonator. There is a large grey electrical connector. Follow the wires out of the connector towards the front. It'll enter another bundle of wires. It's here that the white and purple wire is wrapped in a few layers of tape. Mine is inside a loom in the photos but you can see a little bit of it at the arrow. Unwrap the tape to expose it. I didn't recall if you can see any sticking out. Maybe you can feel it under the tape.
View attachment 185560View attachment 185561
Tap into one wire, or tap/splice into a different wire. i wouldn’t say one is more complex than the other, but at least with the purple and white wire, you’re tapping into a wire that isn’t used for anything else.that looks a lot more involving than just t-tap the brake light harness lolll
i mean for the locks i understand but for CHMSL only... so complicated
oh yeah i know. im just saying it sounds like more steps to do lolTap into one wire, or tap/splice into a different wire. i wouldn’t say one is more complex than the other, but at least with the purple and white wire, you’re tapping into a wire that isn’t used for anything else.
That is, that purple and white is intended exactly for this purpose: wiring up a third brake light in a cap/topper. That’s how I wired up this third brake light on my rack. Hardest thing was finding the wire and removing the tape, but that’s not complicated at all.
Under drivers side tail light cornerI know I’m late to this. I am setting up a topper on my 2022 1500 and was curious if anybody addressed whatever this plug is?
