Built to Serve Edition leveling kit
rayray3
leveling kit question... 2024 built to serve edition,, sticker only states raised height. suspension company says I need a 3.5 inch lift to basically level the front end. I have installed spacer type,, and strut preload leveling kits on regular and Rebel models Gen 4 and 5 .. Problem/question is, the Rebel and Built to Serve are factory lifted,, but are they the same type of lift ???? with a 2-2.5 inch lift.. will I need to replace the control arms or just bolt the spacer to the top of the strut. ??? P S Not good at writing exactly what I am thinking .. So I see several companys list certain kits for Rebel vs Bighorn models as being different. Should I be looking for a leveling kit for a Rebel or Just the Bighorn ?????
The lift on the BTS comes from the springs which I think are the same as the rebel.
I did leveling shock on mine which seems to be the prefer method for most. Belltech , Bilstein 5100, eiback are some choices
I am almost level at 2.5 total up front - 1" from stock spings and plus 1.5" from the leveling shocks. I didn't do new uca's but it is recommended.
many have also done leveling pucks - but if you do like a 2' puck and the 1" from the springs you would 100% need new uca's at 3" lift
Thanks, what I have so far is most leveling kits state not for rebel, on my 2019 I had to do a spacer in the strut. They said no to a strut extension. I cannot figure out if the Built to Serve suspension componets are the same or not as the Rebel.. So you are saying use a whole new strut assembly to obtain the required lift up front. I skipped the leveling on my 2022 due to the confusion on what suspension mods were done to the BTS to get the advertised 2 inches of lift from the factory.
this is the most popular and not to expensive.
open up the instructions manual, and you will see you that you must not go pass clip # 5 - clip 5 gives you 2" of lift and you should add new upper control arms if you are going for the max lift
Our trucks have the off road package that come with longer springs to give us 1" lift from stock not 2" - so if you go with the Bilstein's you will retain 1" from factory due to the springs plus what ever clip you choose to put the Bilstein's at from 0-2"
If you choose to go with a top hat spacer like one from motofab - you will need upper control arms and I heard some people have issues with the spring making contact with the knuckle. I would avoid this option for our trucks.
another thing is to get something from rough country already assemble. Or more expensive coil overs. it just depends on how much you want to spend
Can anyone confirm the lift from the Rebel/ORP/BtS springs?
General thought is 1", but I've read here that the ORP springs are 0.5" and the other 0.5" is the taller 33" tires on ORP compared to 32" tires on non-ORP.
**01/08/26..I can confirm the above Rebel/ORP/ORG/BtS springs are definitely 1" lift and the corresponding tires at 33" give another 0.5" lift over standard suspension Ram 1500 DTs.
How is this holding up with just the Bilsteins and no uca?
It was holding up pretty good but i saw a couple of members brake thiers, i had some money to spare and decided to swap them a year ago. Although the angles with the original ucas were bad when i removed them, they were still in very good shape. I went with rancho.
Here are pics on the angles with original vs rancho. 20240629_143516.jpg20240703_090827.jpg
