Not much input on the Ram, but used to have the dual ARB in a previous Jeep. They do vibrate quite a bit, so don't think I would want it in the Ram box if they tend to warp.
Some would mount them under the hood using a dual battery tray. Others fabbed up brackets to mount under the hood somewhere. I had mine mounted under the passenger seat which could be an option. You only want it inside the cab if it's only going to be used to air up the tires. Don't do that if you're connecting a locker to it, it will give you a migraine by the end of the day. Regardless, I still wouldn't connect a locker to it. You don't want added wear and tear all day when you can run a tiny compressor for lockers. I do have the smallest compressor ARB makes running my F/R lockers.
Also just depends on how much you use it and what size tires. If not using it all the time, might want to consider a less expensive single compressor. It will cost less and take up less space. I started with a Viair 400H under the hood. Keep it there as a spare. It worked fine for 35's, a little slow for 37's.
I'm running 37 X 17 on my Jeep now with lots of under armor. I have a Puma 3/4 HP compressor under the Jeep, above a skid plate. So at least that keeps it out of the engine bay (which I didn't want) and out of the cab. Air valve on the rear bumper.
