HOW TO: Add Digital Rearview Mirror
Here are the instructions for installing the digital rearview mirror in the RAM.
Part List:
Mirror with 1 Video Input Channel, no FCW or ACC - 68448639AB
Mirror with 1 Video Input Channel, with FCW or ACC - 68448641AB
Mirror with 2 Video Input Channel, no FCW or ACC - 68519111AA
Mirror with 2 Video Input Channel, with FCW or ACC - 68519222AA
Center high mounted stop lamp with camera - 68551077AB
10' Fakra Z - Female to Female
https://www.amazon.com/dp/B07P2VBYWZ[/TD]
Parts if you have a 2019/2020:
2021+ BCM - 68496414AD
Wiring Harness from Jimmy07
You only need one of the mirrors. Just choose the one that fits your vehicle and if you want to have 2 inputs or not. You only need the 2 inputs if you plan on adding another camera like cargo, trailer, etc. For the 2019/2020 you will need a 2021+ BCM and the wiring harness from Jimmy07. You can get a used one from a junkyard. You can then stash this under the driver's side dash or the front seats.
Installation is fairly simple. Replace the CHMSL with the new one. Run the cable in the headliner from it to the mirror. Replace the mirror with the new one. Connect the mirror, truck and BCM using the wiring harness. Start the truck and enjoy your new mirror.
2019/2020s will lose auto dimming side mirrors.
For 2021+, use AlfaOBD to set the following settings for auto dim size mirrors.
LIN & Misc: CRVMM Present to NO
CBC Config I/O Usage: RVDM Present to YES
So I bought the digital rear view mirror and new tailight with the two cameras on it and the cable that connects to both what so I need a 21+nvm and ( what harness exactly) ???-thanks
Reserved for future.
Part List:
I also got this symbol what does it mean digital mirror a still haven’t bought the nvm or harness you mention fyi - ( 2020 ram 2500 ) thank you
It means you don't have a connection to the camera. Everything you need is listed in the first post you quoted.
Part List:
Alright so i have the (digital mirror) the (2 camera third brake light ) and the (cable that connects to both ) , now can I used a bcm from a Trx 1500 on my ram 2500 and what is the jimmy harness exactly for ??? Thank you so much !!!
It is really simole process. I have RAM 1500 DT 2020. I got the rearview mirror , 2023 BCM( any BCM over 2021+ will work) , FAKRA cable , and the harness from Jimmy. I think you already replaced CHMSL , ran the FAKRA cable from back of truck to the front and attched it to the mirror. Now if your truck is 2019-2020, you have to use harness to attach it to BCM 2021+. So the harness gets attached to power port of the mirror. Then you have to run the harness cable which is long enough through A pillar and driver door rim to the floor and attach the other side of harness cables to the BCM. The ports that you have to attach on new BCM are self explanatory. You can only fit them on specific slots. What you will notice is that when you go to your car settings after everything is installed, that the mirror dimmer option is grayed out, because your truck’s BCM no longer talkes to your mirror system.
Hey again, can someone please give me the part number for the rear bumper cable housing thingo. Cheers.
I appreciate the OP making this thread. Question though.. will BCM 68496414AE work for a 2019-2020 with jimmy07’s harness? Thanks in advance!
If you are talking about the BCM, then yes. The last 2 digits are just a revision.
Part List:
Amazon.com[/TD]
And now dimmer mode doesn’t work
What year is your vehicle? Did you install it using a 2nd BCM? Or is your truck 2021+? So little detail that it is almost impossible to help you. Have you checked your Fakra cable? Maybe start by explaining by explaining how you installed it.
The truck is a 2021
The truck is a 2021 with a bcm
It a 2021 truck with a Bcm 68496414AD and yes I check the fakra cable but with I read here it tell me that the dimming showed work but it doesn’t and every time I flip the mirror
The mirror tell me no video I
Looks like an actual issue with the camera.
If you unplug the fakra cable from the mirror, do you get this image instead?
no it stay the same
