Ortiz7983
- Nov 6, 2018
Hello guys, I have a 2019 1500 non Etorque and I have never changed the transmission oil or filter for it. I’m curious if you guys think I should change it now doing a drain and fill, not a flush. I have 120,000 miles on it but they are mostly highway miles. If you guys do suggest it, I’ll be using the Mopar transmission oil and filter.
As for the motor oil, I always change it at 5,000 miles and I used Pennzoil Ultra platinum. Do you guys recommend me using the same oil or should I switch over to the Pennzoil high mileage platinum?
As for any other fluid changes and lubricants, can anyone else help with what other things I should be doing? I’m not sure exactly on what I should be lubricating, greasing, or what not.
Your help, suggestions, and opinions would be much appreciated.
