Mountain Whiskey
- Mar 2, 2021
CIA experiment. Random things in your house are laced with LSD so the doses are as random as the mystery noise in your truck.
Wouldn't you just poop yourself if you found a harmonica!! Just imagine how many beers you would have to buy us...Appreciate everyone's ideas. I'll try recording the sound on my next drive.
Seriously tho, I hope you find what is causing the noise...
Had that with my old work van anytime I had an extension ladder on it. Was angled just right the air blowing over the ring tubes was like blowing over the mouth of a bottle.I actually like the harmonica idea, laughed myself silly the first time I saw it. I must try it sometime. Can you recommend an inexpensive brand suited to road conditions?
But seriously, there are plenty of acoustic opportunities under and around the truck.
Anything tubular with an open end is a potential tuned cavity that can sing like a flute. One friend had an aluminum ladder atop his service van that loved to hum. I believe a bit of expanding foam in the ends of the rungs cured that.
Just examples, hope you find it, we're all curious.
I can name that tune in 4 notes... But you have to be old enough to know what I am talking about...Had that with my old work van anytime I had an extension ladder on it. Was angled just right the air blowing over the ring tubes was like blowing over the mouth of a bottle.
Name that tune.I can name that tune in 4 notes... But you have to be old enough to know what I am talking about...
Can't find F'n noise!Name that tune.
this noise haunts me in my dreams.Can't find F'n noise!
@Pop's Ram, I'm curious if you were ever able to get to the bottom of this noise. My truck has 153K miles and this noise started in the last few thousand miles. It's getting slightly worse as time goes on. I never hear it when idling, which is often, and it exhibits no similarity to a bad wheel bearing. It comes and goes with no input from me and nothing I do (braking, acceleratiing, turning the wheel, etc, etc) seems to alter or stop the noise in any way. The volume of the noise has always stayed consistent, and the duration of the noise is anything but consistent. Happens at all speeds. I will try the ANC fuse thing to be sure.My truck has gotten progressively worse over the last month or so. After doing a lot of searching in the forums, I was convinced it was the ANC system. It happens when I'm alone in the truck or with a passenger in the front. I very rarely have anything or anyone in the backseat. Yesterday on my way home from work, it started doing it again, so I pulled over, left the truck running and pulled the F12 fuse for the ANC system. Radio sound went dead (as expected). Started driving again and was hoping to hear silence. NOPE! It continued. Any ideas? Could it be the front active air dam moving? Grill shutters? It's not consistent - happens while keeping steady speed/rpms, foot off the gas, foot on the gas. The droning goes up - goes down - stops - returns. It doesn't change with anything noticeable. Doesn't sound like a bearing. I can't be without my truck as I use it to get to work, so I'm reluctant to take it to a dealer until I'm fairly convinced what it is.
Well - never found the source of the noise, but it stopped as the weather got warm. Never heard it all summer long. Now that winter is upon us again, she's a moanin just like before! No pattern - no increase or decrease with speed - and I STILL haven't found the harmonica@Pop's Ram, I'm curious if you were ever able to get to the bottom of this noise. My truck has 153K miles and this noise started in the last few thousand miles. It's getting slightly worse as time goes on. I never hear it when idling, which is often, and it exhibits no similarity to a bad wheel bearing. It comes and goes with no input from me and nothing I do (braking, acceleratiing, turning the wheel, etc, etc) seems to alter or stop the noise in any way. The volume of the noise has always stayed consistent, and the duration of the noise is anything but consistent. Happens at all speeds. I will try the ANC fuse thing to be sure.
Hoping someone may have some new information.
Well - never found the source of the noise, but it stopped as the weather got warm. Never heard it all summer long. Now that winter is upon us again, she's a moanin just like before! No pattern - no increase or decrease with speed - and I STILL haven't found the harmonica. All kidding aside, it's annoying!
Bummer! I wish it were as simple as a dang harmonica...both an easy fix AND and respect for whoever would have done that to me. I may need to use that trick on someone someday soon. In fact, I have a harmonica in my truck as we speak so I am armed.Well - never found the source of the noise, but it stopped as the weather got warm. Never heard it all summer long. Now that winter is upon us again, she's a moanin just like before! No pattern - no increase or decrease with speed - and I STILL haven't found the harmonica. All kidding aside, it's annoying!
I will try to get one, but I'm afraid the moaning noise won't be loud enough to be audible on a recording. will give it a shot...stand by.Do you have an audio recording?
Well it certainly sounds like we have the exact same problem. I had a mechanic tell me of a non-urgent concern about one of my axles/differentials, but that it was far too early to worry too much about it. I'm trying to reach hime and will advise if this is at all related.My response would be the same as Andymax - I've had a tonneau cover since (almost) day one. It's not the ANC as I pulled the fuse for it and it still happened. It's only happening in the colder weather. Doesn't matter if the truck just started or has been driven at normal operating temps for a while. It pops up at random times with no noticeable pattern or cause.
