I keep going back and forth about to order with or without e-torque. So what do we feel are the pros and cons and ultimately what would you choose even if your choice would have changed after you received your truck?
At least it’s covered by the 8 year / 80K mile emissions warranty. That’s better coverage than the rest of the truckIf you are buying off the lot, and the truck that has what you want has an etorque and is marked way down then it might be worth the roll of the dice.
On the other hand if you are ordering, it's really hard to justify going out of pocket for an unproven contraption that might very well might go bonkers at some inconvenient moment (like 5 miles after your warranty expires).
With all that said I'm getting great mileage, and the little bolt-on miser is working perfectly in all of my 600 miles thus far.
Nailed it.The battery regenerates the same as any other hybrid type, by brake use, one FCA lady said. But they call it a Mild hybrid.
Given what i understand of it, its explainable why any gas savings are minimal to none. Its used semi rarely and in those start from go positions, and if you take a highway trip, ajd leave exit 52 of whatever state, drive your full tank without stopping, you shpuld see zero difference in tank mileage, given rhat the conventional 5.7 was running that entire time.
Now, I COULD BE WRONG, I know. But depending on your lifestyle and driving needs, to factor in whether it would be any good to you.
I think if anything, it would give a more city driver more of the boost in gas savings.
Algorithym and equations I believe. EPA doesnt physically test for hundreds and thousands of miles, so to speak, to get figures. EPA gives the numbers. Factoring the benefits of stop and go fuel savings, I can understand the higher City portion and thus, higher average. The highway portion creates confusion.Here's the thing though, *somehow* the eTorque version of the truck was rated 2 Mpg higher than non. It's been rumored that somehow eTorque helps the MDS stay in longer but I don't think I've ever seen that officially stated. Which makes me wonder FCA pulled off the extra 2 MPG.
That’s been explicitly stated. It also has been explicitly stated that the system smooths out shifting under load and (obviously) during stop/start. I feel like we’re starting to rehash ancient eTorque threads now...Here's the thing though, *somehow* the eTorque version of the truck was rated 2 Mpg higher than non. It's been rumored that somehow eTorque helps the MDS stay in longer but I don't think I've ever seen that officially stated. Which makes me wonder FCA pulled off the extra 2 MPG.
eTorqueI have it. Total waste. No benefit whatsoever. Another thing to break. Seems pointless.
This technology has been around for more than a decade, when 42V systems were first being explored. It was too expensive to prove cost-effective then, but as 48V systems have become more popular (for other applications), the cost to implement a P1 hybrid system in a vehicle has come down significantly. And everything cheaper (e.g. lightweighting, turbocharging, etc.) has already been largely explored. FCA first applied the "eTorque"-branded system to the Jeep Wrangler, and now to the Ram. Other manufacturers will undoubtedly continue to explore this and a host of other hybrid/electric options in the quest for reduce emissions and improved efficiency.The other thing I wonder, is where did they get this technology? I mean a belt-starter-generator... who came up with that idea? Any other car ever built have such a thing? Is it good or bad to do it that way?
And the monster alternator - is its power really available to the rest of the systems? Can I power a rail gun or tesla coil with it?
Right now I'm thinking it's a slightly improved start-startup feature best suited for door-to-door delivery services, e.g. UPS. I think if they just pitched it as that there would be a whole lot less flame threads about the thing.
