ppremier21
- Mar 14, 2024
The other evening I went to start my 2019 Ram 1500 Limited and it would not start, heard a "popping" noise in the speakers. After researching it was determined to be the battery. I replaced the battery and it fired right up. However, since starting the truck with the new battery, every single warning light is on and says needs service. The check engine light went off on it's own but literally everything else is still on; service cruise control, service air suspension, traction control, ABS, parking sensors, rear assist ect. you name it and its illuminated on my dash. I have tried unplugging the battery but that does not work. Dealership wants to set up an appointment which I am sure with be a few hundred dollars. Anyone else experience this issue after changing the battery???
