Fbird
got my TAZAR DT installed and adjusted for my 35" BFG's. Not BAD but definitely not exactly plug n play per the directions. Does it's job. I must calibrate per the highway next week but is really really close per my gps. MY number was 34.5" per BFG website. IIRC there is a 34.4" selection in the menu as well. Better than the 9% overspeed compared to the speedo!
TheLegend
Got the Lasfit switchback rock light kit installed went with the 8 pod kit. Just goes so well with my other lights that are Amber and White.
boogielander
went camping with friends and customers from the shop this weekend.
yeap that a 392 on Fox 3.0
Took the long way out
Getting some slider actions in. This is exactly why I said steps and running boards are no good for those who take their trucks off pavement.
This i fell into that hole as I got off the truck.
Perfect spot for an oil change?
CHeYeNNe71
Sounds interesting! Any irl photos of this combi or at least of the wheels on this model of Ram?
I don't know of any offhand, but I'm sure if you google, they might pop up. I want to go aftermarket wheels, but it's costing enough with the BDS 3" lift w/ Fox and tires. Maybe later in the year or next year. I thought about Gray, but not sure how that would look with the color.
WasatchBack
I was thinking about upgrading my Auxito plasma yellow LED fogs to the DD Elite’s. But now I may have to rethink that. What went wrong with them? Why not contact DD as I’m sure they’ll do their best to make it right.
I run all DD auxiliary lighting on both truck and car. Rock solid never an issue, must be a one off issue.
Ready Go
Wisconsin
.....JUST in time (I'm 100 miles from an oil change), I called Jim Foster at Pacbrake this morning and the updated HP10596 that replaces the HP10363 is now available in the US warehouse, so I've got one on the way! I've got a Fumoto F106S already and an SRT Oil Filter (had a couple left over from my Challenger SRT392), so just need to pickup some oil yet.
Insanity
I should give him a call and see if I can get the updates orings. I still have to install mine.
Gren71
Delaware
Just took about 40 minutes to install with running the rear camera wire. Most difficult part was removing the front panel on the factory housing.
Sorry if youve already answered this, im still working through the thread.
Do you find the camera gets in the way of your field of vision? The way I sit the large plastic housing already blocks a portion of my FoV. This camera is an awesome idea if it doesnt block up the entire world
bigdodge
Happy Ram Owner
the camera case is the same size as what is already there from the factory
boogielander
hmm i think with that location i don't need to take out my front filler plate to do it!
Gren71
Delaware
The camera its self looks like it sticks out from the bottom of the plastic housing, making the entire unit larger. How I sit I have to look under that part already. Which is why im wondering if its as obnoxious as it appears in the pictures.
Eighty
Moderator / Dream Killer
Not sure if yours is the same style as mine, but here’s what it looks like in reality. I don’t ever notice it’s there.
boogielander
same. i don't notice it's there
also if you have covercraft windshield cover this is probably the only option that still fit very nicely. Other dashcams get in the way of the windshield cover!
