Alaboss82nd
- Nov 25, 2022
Anyone put Firestone Destination x/ts on their Rebel? Any feedback?
Maybe a stiffer sidewall over the duratracs? That would make sense for it being bouncier and less lean.i have them on my rebel and have been happy with 10k miles. a lot less noise compared to the oem duratrack, i replaced mine at 75k miles. it seems more bouncy but leans less on tight turns if that makes sense. i know that in my logic, if it's bouncy, then it should lean more. no change in mpg. even though it's the exact same size as duratracks, visually it looks narrower (width). it also loves to pick up gravel. and as you can see, it's not as aggressive. wet and dry road behavior is good. haven't tried it in snow or off road. View attachment 178083View attachment 178084View attachment 178085
How have you liked them overall. I found that the ride smoother and better mpg in the city. Not as heavy of a tire as the BF Goodrich’si have them on my rebel and have been happy with 10k miles. a lot less noise compared to the oem duratrack, i replaced mine at 75k miles. it seems more bouncy but leans less on tight turns if that makes sense. i know that in my logic, if it's bouncy, then it should lean more. no change in mpg. even though it's the exact same size as duratracks, visually it looks narrower (width). it also loves to pick up gravel. and as you can see, it's not as aggressive. wet and dry road behavior is good. haven't tried it in snow or off road. View attachment 178083View attachment 178084View attachment 178085
