Need some help with Alpha OBD
Tango51
S. Fl
I'm trying to program a new key fob for my 2022 truck and I can't get the alpha obd program to read the 5 number pin code so I can program the key. Everything is hooked up correctly but it ends always with an error. I've tried it with the key in the accessory mode as well as off but no luck. I have programmed passive entry in the truck a few months ago and it worked perfectly but I did not need a pin code for that. Any thoughts..Thanks in advance.
Idahoktm
North Idaho
I was under the impression if you have the five digit pin you could.
Nope. You'll have to take it to the dealer. I believe a locksmith can do it too, if they have the right equipment.
Jako
Borough of Parks
Some additional info
Nascar Tommy
My other Ram is a Dodge.
NW Indiana.
thank you
I too have an alpha and I was told it could program a fob if you have the pin. I was unable to get my pin.
Are you sure your pin is correct?
Don't reveal if you don't want to, but where did you get your pin?
Moparmaniacca
Saskatchewan, CA
Dealer can look up your pin. Just need your license and registration, charged me $5 to do it for my Challenger. AlfOBD was pulling the pin, but it was wrong...
Darksteel165
Massachusetts
Can't do it with Alfaob. It's a rolling pin, so what pin did they give you for your Ram because it wasn't what you needed.
I know there is a $300-500 device that can do keys, but that's way more expensive then just paying a locksmith.
Moparmaniacca
Saskatchewan, CA
I haven't tried it on the Rebel, only the Challenger. Was just stating that even if AlfaOBD could pull the pin, it doesn't mean that it's correct. I'll be going to a locksmith when it's time to add new fobs to the Rebel, as the dealer wants $195 for programming.
Tango51
S. Fl
195.00 isn't bad the locksmiths around me want 200.00
oe542bob
When I bought my 2018 Ram 2500, I asked the selling dealer for the 4 digit pin and it was given to me without any problem. In that case I needed it to reset the TPMS to access the RF hub. ( used AlfaOBD )
Last year when I got my new 2022 1500, I asked the service manager/owner for the pin. He stated that there is a rolling PIN number now. So in certain circumstances, you’ll need the dealer to do certain programming.
Of course, if you are somewhat nefarious, making a new FOB seems to be no problem for criminals cloning a new FOB to steal a Ram, Challenger, Charger, etc. !!!
Nascar Tommy
NW Indiana.
Not every dealer will do it. After my dealer refused me I contacted Stelantis and they said dealers are NOT supposed to give customers pin numbers. So if you got one and it works consider yourself lucky.
