Just posting in case it helps someone else.
If you take up driver sill plate, under the carpet and wire holder, there is a thin green and white stripe wire. It’s the tailgate button sense. I was able to ground it thru a 2k ohm resistor and it pops the tailgate.
There are several green and white stripe wires in this harness. I verified by disconnecting battery, and uses multimeter between ground the probe the green and white stripe wire. Mine read 2.6k ohms at rest. And goes to 1.4k ohms if someone holds the tailgate button.
Useful if you wanted a switch in the cab to drop the tailgate.
