2019 1500 Laramie rear seat belt replacement
vdavidoff
All my rear seat belts are damaged and I'm swapping them with OEM parts. It looks to me like I'll need to pull the rear seat to do this. I am wondering two things:
1. Does anyone have any tips on doing this work? Are there any gotchas?
2. Do I need to be concerned with air bag stuff when doing this work?
Thanks.
Andy
Thanks.
Andy
"WARNING: Before Repairing Any Restraint System, The Battery Cables And Any Back-up Power Supplies To The System Must Be Disconnected In Order To Prevent Accidental Deployment"
You need to read up on the procedure before doing this work, specially if the squib`s have not detonated.
Might also want to get a cheater bar for your wrench.
Thanks. I got a 3 day service library subscription to get all the official info.
Andy
I had to replace my drivers seat belt. There was an airbag cluster light that cleared after a few drive cycles.
I doubt the rear seats cause this because they don't trigger the seat belt warning. But just a heads up incase you see a temporary cluster light.
Cool, thank you. I did notice the verification process requires a scan tool, and wondered if not having that, and therefore not being able to do the procedure, was going to cause any issues. Guess I'll find out.
