Black_Widow1500
- Feb 7, 2021
I don't have them, as my truck came with the Mopar running boards, but I'd recommend the power side steps that extend out when you open the door and tuck up when driving. If I ever replace mine, that's what Im getting.Hello,
I just purchased a 2024 Ram 1500 Lone Star/Big Horn V6 etourque Night Edition.
I'm looking to buy some running boards for it. What do you guys recommend?
I don't what nothing sticking way out. Any ideas or models and photos are greatly apricated.
Thanks. View attachment 176890
Hello,
On a side note to HSKR, if you go with folding running boards, definitely recommend some PPF protection, due to rocks being flung up from the front tires and hitting the rear fender. Common issue on these trucks and the fix is either a stationary flat style running board (like OEM) or PPF on the rear fenders.
Just be careful with the Mopar ones as they have a "pocket" that collects rocks/dirt. I have the Husky ones and really like them. Molded to the continues of the truck and no drilling requiredGood point. The rear tires will also fling rocks into the lower rear fender so some form of protection will be beneficial regardless of running boards.
I installed the Mopar splash guards right away and it stopped all the debris from accumulating on the rocker panels and lower rear fenders and they look like an OEM option.
Newer design, many complaints on the original design filling with road material/ice/snow/slush.. There are some other brands, some are shorter or longer than OEM. Some info below, there are other threads with pictures and recommendations. One member cut his down a bit and looked good.Mine don't have a pocket that holds dirt. They came with a dense foam insert to fill that void.
