Is this ok?
Emiliomcol
Good day to all! I just wanted to get opinions on this, I took my 2022 big Horne for oil change and they are recommending to change the drive shaft and driver side rear axle since is leaking oil. Both things are covered under warranty but still a one year old truck which is a pavement queen and no towing ever, is this normal to happen or is just bad luck?
Thanks in advanced!
Rick3478
NW OH
You didn't say how many miles, so I guess if it's covered by warranty okay to replace, but it isn't normal for either of these parts to be early fail.
Kiwiaudio
Ohio
Well, driveshafts and axles dont leak oil, seals do. Unlikely in your case, but we cant see it. Get another opinion from a pro that can !
Emiliomcol
Currently 26k miles. On the drive shaft the guy mentioned ball bearing failing but need to replace the whole thing and on the axle there is oil on the metal part to the wheel. Sorry if my explanation is vague don’t know the mechanic terms.
Thanks
Fbird
take it to a dealer MAYBE you get an actual mechanic to eventually look at it. As stated above axles do not leak oil the axle shaft SEAL maybe and a driveshaft does not have bearings, other than the needle bearings in the u-joints which are replaceable. No neither of those components SHOULD have an issue at 26k but occasionally someone has to get a less-than-perfect part. It's the law of averages.
Emiliomcol
Thanks for your reply.
Everything it’s covered under warranty is just that both things failed at early stage is disappointing.
Here is the video the dealer send me with the inspection if anyone wants to see what they said.
H2OMAN
The O.C.
Who cares what they want to replace under warranty. It makes it new to you. Go for it.
kapinallinen2
5thGenRams Supporter
Southern Maryland.
Nice interaction/feedback to the customer.
I disagree with the comment about having more thread on the driving axle tires v.s steering.
