Default startup screen
cliffsta
I have a 2023 Rebel with the 12” UC5. Absolutely love it. One quirk I’ve found is that when I start the truck, the screen always goes to either the Apps page or the Favorites page. I would much prefer the screen defaults to “Home” since that has the panes set up with what I want. Am I missing a setting somewhere for this?
Do you plug your phone in to listen to music?
Mine is like a roulette wheel also, you never know which page will pop up..Home "most" of the time, but I'd never place a bet on it.
If I added any widgets related to CarPlay on any of my home screen pages mine was also like a roulette wheel each time I started the truck. Deleted pages with car play widgets and it is much improved. Remote start will still confuse it though. It will open one screen upon remote start then switch to another screen when I push the start button.
I do not. I use wireless CarPlay.
Others: I do have CarPlay as the top half widget on my homepage with audio and climate at the bottom. Maybe I’ll try removing it and seeing if it more consistently starts on one page. Remote start or not, mine seems to hop around lol.
I had that problem a lot until a software update helped fix it. Now it happens very rarely and 99% of the time it's on my Home screen when I start the truck. You can check your version under Setting, System Info. Latest one I've seen ends in 27.46 I believe.
