Are yours D rated?
E, I think they were at 44lbs before but I had them road force balanced and rotated before my roadtrip and the tire shop said they set them at 39lbs. I haven't looked too much into it since to be honest.
Are yours D rated?
What size are these?Here is a shot of the KO2's I added to my stock 20" Limited wheels. Not sure how they compare to the Laramie wheel. Love the tires. I have had them on my last few Rams. View attachment 3403
How are the KO2s as far as vibration and street ride smoothness (is that a real word?)?
Lobo. So you mention 275 65 20 will fit. Is that a stock limited 4x2 or 4x4 (does that matter) with air suspension and no ORG?275 65 20 fit no rubbing but still opted with a 2inch level kit from Suspension Max
What size?Just put some KO2s on my Laramie!
Question is your truck sitting perfectly level with the 2 inch level? I read that with the 2 inch level it still off by a half inch?275 65 20 fit no rubbing but still opted with a 2inch level kit from Suspension Max
I have a 2” level with 285/65-R20 KO2’s on stock Bighorn rims. Have not noticed any rubbing. They ride great.With a 2.5 leveling kit will 285/65 R20 tires fit the stock big horn wheels?
You happen to know what size they are? That's the exact look I'm afterThese were found on the interweb...shows more aggressive blackwall tires on OE Laramie 20s. I will be doing the same thing when I add my leveling kit soon.
I'm looking for a pic of the stock 20" Laramie wheel on stock-size KO2s. I like the way they look with the white outline lettered Bridgestones, but I'm concerned the blackwall KO2s won't look as good.
With or without ORG? Curious as to which stock tires you’re comparing.275/60/20 KO2’s on stock Laramie longhorn with stock air suspension. No rubbing at any suspension level and quieter than the tires it came with from the factory.
