2022 Rebel blown engine
I've just rolled 110,000 on my '21 BTS eTorque 4WD. I've done all my own oil changes and maintenance. The dealer has only seen my truck once, 3 months after new for complimentary oil change. I checked over the engine afterwards, I swore it wouldn't see the dealership again, AMSOIL every oil change since then. I always put top end cleaner additive ever few thousand miles and fuel injector cleaner every other fill up. That ethanol will wreak havoc on engines, unless you find a pump that serves up ethanol free gas (MURPHY USA). Do your own maintenance if your able.
Modern engines are designed for ethanol. It won't cause any added issues. As long as you are running top tier fuel and switch brands every now jow and then(different detergent packages). Do I prefer ethanol free? Certainly, but that's only because it gives better performance and fuel mileage.
1.21gigawatts
7-Stringer
Boston, MA
I was just curious if they were built in different plants Like the pentastars are... but it looks like both are built at the Santillo plant.
Darksteel165
Massachusetts
No one has tried it yet, but i'm pretty sure you can convert an eTorque to a regular alternator.
Would require the right parts, and a flash of firmware or 2 but I think the inners of the engine are the same.
We will find out in another 7-10 years as these batteries die and people don't want to spend $2k for a battery (yes I know they are cheaper now) of $1k for a generator (alternator)
