Rebel suspension on a 1500 bighorn?
Justtom
Justtom
Sounds like you're not gonna get this, which is good. You'd be wasting your money unless the parts were nearly free. The UCA's are the same as those on your Big Horn. 1 front shock is useless. The rear shocks alone probably aren't worth the asking price since he's including the other parts. I have no idea what the other random parts are so I can't really comment on those.
Yeah the work, the cost of parts, and cost of an alignment for a 1" lift? No, not worth it. I'll have to go aftermarket for UCA's it seems like but there's a bunch out there. I don't do any serious off roading so it's mainly for the look but I do want to make sure it's done right.
CHeYeNNe71
Highly recommend the RC M1 upgraded struts which are Monotube and Spec like the Bilstein 5100 over the lower quality N3 twin tube.
Redz72
Langhorne, PA
That looks great! That's exactly what I'm going for, it looks so much bigger next to the rebels too. $300 isn't bad. What size tires are you running?
Love that look!
Thanks brother. I am running 285/65r20 Yokohama Geolander AT G015. They measure 34.8x11.6. I’m very satisfied with how it rides. It’s a bit firmer than stock considering it has LT tires now. But cornering is better with a stiffer strut and paired with the rear Hellwig swaybar, she’s a blast to drive.
Justtom
No problem, yeah I like the way those tires look. I haven't seen alot of people run them. Thanks for the pics/info!
