How dark are the back windows tinted to and will ceramic tint up front match close enough to the back?
Jake1050
Like most people I want to tint the front windows to match the back. It doesn't have to be a perfect match but I don't even know how dark the back windows are from the factory. Questions:
1. Will ceramic tint on the front windows look different from the back? And should I shoot for the same darkness as the back? What percentage is the back?
2. If I do the brow across the top of the windshield is going a little darker than the front windows going to be too noticeable?
Any good tint shop will match the factory tint. I just did ceramic tint and it looks great!
I agree, skip the brow.
Rear windows are around 25%
Looking different depends on the tint used.
I personally wouldn't do the lame 6", I went full windshield 50% and a 10" strip of 5%.
I went 25% up front, and it's a little lighter. I also did a really high ceramic in back, but it didn't really darken much, which wasn't the purpose.
I disagree on the brow. I did 15% and love it, but I'm lame... 😄
Keep in mind the back windows while darker, are only colored glass. You’ll want to put something over them if you want heat rejection properties, a must have here in FL.
My guy did Llumar FormulaOne Pinnacle 15 on the back, 5 on the fronts and 30 on the windshield. Fronts and back are a perfect match which was important to me. Probably darker than you want but that’s what worked for me. Made black on black tolerable in FL.
My tint shop put 3M Ceramic 15% on the fronts. It looks like a close match but it's a little dark for me at night personally. If I could do it again I would have done 20% on the fronts. even if it wasn't a perfect match.
I agree with what the others have said, the factory windows are dyed glass and not tinted.
did 20% all around with 50% on the windshield and pano roof. back is a little darker now, but I am ok with that...
How long have you had the pano done? I've heard horror stories it retains the heat and can blow out the window. I left mine alone for that reason. When I lived in Az the couple shops wouldn't do it for this reason.
I've had mine done for over three years with 20% film. Zero issues
Mine is 32% on the fronts, 18% on the rears but the back still looks darker.
I'm 70% on the windshield and 18% on the Pano sunroof.
I've heard the same and didn't do mine either. It sure gets hot in Texas though with the shade closed.
I don't like the brow because the few vehicles I've ridden in that had one, it was annoying. The cutoff was always right in my line if sight, so I was either trying to stretch up to look through it, or duck down to look under it. I wear sunglasses when I drive anyways so it doesn't really do much for the sun, IMO. I never use my fold down visors.
The brow is subjective to driver height and seat adjustment. Pretty sure you are a few inches over 6' where I'm 5'9 so our perspectives are somewhat different.
I very seldom use my visors but would never need to if my brow was an inch lower. My tint guy talked me out of it but I wish I had stuck to my guns and gone lower.
My brow is around 6" at the mirror and closer to 10" at the edges. I'm 6'2", and use my visors whenever necessary. I also cannot drive without sunglasses. Missouri won't (or didn't last I checked) allow tint below the whatever they call it line.
I've never measured mine exact, but in the middle it's even with the bottom of mirror. IL doesn't allow like many states below the As1 6" line. Rules are meant to be broken. :cool:
I have 20% over side windows and even the windows on my Leer topper. I didn't do either rear windows Cab and topper, since they have tint from factory on them.
