1BADRAMLIMITED
Can I borrow your TAZER???Definitely can. I've done them in mine, but I use my TazerDT to completely kill TCS/ESP
Any video of you doing flat spins?????
No videos that I know ofCan I borrow your TAZER???
When you are just spinning in a circle but staying in one place.What is a flat spin? We only have donuts here...
Didn't know Tazer could kill TC/ESC, cool.
I will say this - My '04 GMC had a stick transfer case 4WD and a Gov-Lock axle. When I needed it, just pulled the stick. Ram have to push the 4WD button (hidden by the steering wheel), push the axle lock (also hidden, and only good for 25mph), and turn off TC. Tried to go around a city corner in the snow this am and couldn't engage while spinning, holding up traffic. Arrgg.
Also, doesn't someone make a harness for the F26 fuse? Was marketed for the 4th gen, but still should work in the correct slot.
If you have a battery charger, should have connected it to new battery to ensure it was fully charged before putting in the truck. When I did mine it took four hours to hit full charge with my Optima battery charger.Rebel now at about 2.5yr mark, started noticing labored startup. Checked OE battery, 11.5v with engine off. Tried an overnight charge, no change. Called dealer, 2 weeks out for appt. Screw it, picked up Evercharge Platinum H8 at wallymart, 4yr free replacement. When I swapped batteries, used jump and carry to maintain power to truck. $180 for new battery worth avoiding the likely stress/frustration of a dealer encounter, yes for me.
Looks Great!!
Now you need a rubber mat to protect the plywood thatās protecting your bedliner.Bought a piece of 3/8ā CDX plywood and a gallon (overkill) of black exterior paint. Cut the sheet down to 66ā for my short bed, then painted the plywood.
Now I wonāt scratch the spray-on bed liner. Wouldnāt want that to happenā¦![]()
I have a Lomax on order, then will use a blue Harbor Freight tarp over the whole thing.But the rubber mat will soon become discolored and brittle if left to the elements, so it would be wise for him to invest in a bak-flip bed cover.![]()
No, he would be better off putting a piece of 3/8ā CDX (painted black) over the rubber mat. That would protect it pretty well.But the rubber mat will soon become discolored and brittle if left to the elements, so it would be wise for him to invest in a bak-flip bed cover.![]()
So plywood rubber mat plywood.No, he would be better off putting a piece of 3/8ā CDX (painted black) over the rubber mat. That would protect it pretty well.
And probably a tarp on top of that. Donāt want the plywood to get wetSo plywood rubber mat plywood.
A 50lb bag of sakrete on each corner to hold tarp down.And probably a tarp on top of that. Donāt want the plywood to get wet
You must have missed the HF tarp I already spoke of.And probably a tarp on top of that. Donāt want the plywood to get wet
Why not use bedliner sprayed on the plywood? That would protect it from deteriorating due to exposure to the elements.And probably a tarp on top of that. Donāt want the plywood to get wet
