Help me decide
1BADRAMLIMITED
Oklahoma
I’ve been scanning custom offsets, google and a 100 other sites trying to decide on what setup I like the most. But there are soooo many dam choices it’s overwhelming
I have a 2019 limited org with airlinks front and back which provided a 3” lift in front at 1.75 or so in the back.
Leaning towards 20x10 but I’m not sure on offset. I really like the poke of -18 but 0 offset is nice to for the simple fact you don’t have the “bro dozer” look.
I also like the 18x9 or 18x10 same offsets as stated previously but I’m not sure a 18” on a limited fits the luxury look. I feel 18” w/ meaty tires go well on every thing but a limited (love 18’s on rebels)
Can you all help me make a decision by sharing pics of the specs listed, I would greatly appreciate it!
Also looking to pair the wheels with 295/65 or 35x11.5……
I agree with the slight poke look. The truck looks worked, but not bro-dozered. I have the stock 20x9 with 1” rear and 3/4” front wheel adapters for the slight poke. View attachment 174621View attachment 174622
yea i have 1.5 spacers on my stock 20x9's and some times i feel the "poke" look takes away from the limited. I feel a limited should sit flush since its not really enginered for off roading like a rebel , trxt etc.
I'd personally stick with a nice set of 22X10's which is what I'm doing. I'm looking at Vortek wheels Series 1.
Vortek Wheels
I looked at both Vortek 503 & 504 and 4Play wheels. The Vortek look great but also look like a Bit@h to clean because of the lip design so I ended up with 4Play. 22x10 -18.
Those look good. How’s the ride with 22’s wrapped in 33’s? I think if I run 22’s I can get away with a 35” tire.
Thank you. They ride great and balanced well. The ride also was due to the suspension I had. I ran 285 50 22. Was able to keep my wheels/tires when I traded the 23 Ram for the 24 Ram. This time, I may go to 285 55 22. Don't want to trim anything.....
Im in the same Dileema. Been going over Custom Offsets site for 3 days Now. Its Maddenning !
I have a White 2023 Ram 1500 Lonestar 4wd.
I think I finally decided on
2in Level
20x10 -19 Hardrock Affliction Black Gloss
Toyo AT III LT295/55R20
Any Thoughts?
2in Level
Any Thoughts?
Looks like a nice combo. I'm a big fan of the Toyo AT3's.
2in Level
Any Thoughts?
I think i finally narrowed it down to 20x10 or 20x9 but still not sure on 0mm offset or -18
My thought is if i get tired of 0 I can add a spacer and get a nice stance and return back to flush anytime.
Tires are the next fight. I’m learning about load ranges and “ply” 😩
do you take your truck off pavement and do trails?
if so you want more meat than wheel. Those 2 inches in diameter makes a lot of difference. Heck I went from 17 wheel 33 tire on my previous rig to 18 wheel 33 tire on stock rebel and I felt the difference lol
35x12.5R18 Wildpeak AT3w, 18x9-12mm Method 305 NV Bronze
Not really a whole lot of poke. Still flush enough and not poke out as much as -18 or more aggressive styles.
What is the weight per wheel/tire with your current set up?
The only thing is you're then stuck at 1.5", maybe 1" spacer which will stick out more than -18. You're saying already you don't want much poke. Just a thought.
