changing odometer from kilometers to miles?
Randy L
CA - California
Cannot figure out how to get odometer back to miles from reading kilometer? Also all my temperatures are reading Celsius...speedo reads mph! I have gone thru all settings on steering wheel,what am I missing? Thank you in advance,Randy
Didn’t your truck come with an owners manual??? It’s in the settings of the Uconnect somewhere, check the manual or just go hunting around. Maybe under the display section of uconnect settings?
You should be able to correct this by going into settings and making changes. I noticed last night while driving, I must have bumped something which changed speed from mph to kmh, found that all I had to do was hit “okay” on left side of steering wheel to change that back. For, that was the only thing that had changed to metric.
Correct, when the screen setup display is set on the speedometer just hit the ok button on left side of steering wheel to go back and forth from mph to kph like Redrider mentioned, very simple. Sometimes I accidentally bump it as well.
I think the one on steering wheel, only changes speedometer? Where uconnect changes trip/odometer etc? Maybe?
Uconnect settings menu look for Units...select US
This is correct. The uConnect setting will change the odometer back and also change the temp back to Fahrenheit.
Thank you all for the replys,big help! Like knitro84 said it's in the uconnect under units. Thank you!
OP is correct I have my speed set to KM/H and the average fuel economy is set to MPG. One would think when you set KM/H all readings would be in metric and vice versa if it is in imperial. Also Uconnect health status does not work with the 12" screen the only think you can do on uconnect with 12" screens is remote start/lock and unlock
