ECO not lighting up
lawn4cr
Hi all,
My ECO mode doesn't seem to ever activate. I see it light up very infrequently and normally in the range of 23MPH (50KPH) - 27MPH (60KPH). Second Ram I've owned so I'm familiar as to when it would come on. Last night I was at 45MPH (100KPH), 1500RPM, long straight stretch, cruise control. ECO never lit up.
Looking for a little help on this one.
It doesn't take much engine load to turn off 4-cylinder mode.
Is Tow/Haul mode is enabled? That'll keep it off.
Steve
No it sure isn't. I can say with full confidence the ECO never comes on at any cruising speed.
Is it turmed off in the settings? There is an option to disable it showing in the cluster.
Sent from my SM-G781U1 using Tapatalk
I had the dashboard Christmas tree lighting from the pedal commander. After that, it never came on again even after resetting codes and removing the PC.
Hmmmm... Does your Pedal Commander have a disengage setting. Maybe a disengage would allow the ECO light to show more frequently....
Sorry, I missed the part where you stated you disconnected the PC ....
Have a 22 rebel, mine only seems to come on when I let off the gas, comes on for maybe 10-20 sec then turns off
Mine rarely comes on. For sure never when any throttle is applied. Mostly only when coasting down hill.
Hi all,
Thanks so much! View attachment 173849
ECO turns on every time its a long stretched road and steady speed, provided i am not using cruise control. Under cruise control it never turns on despite driving under the same conditions.
It is on. The weird thing is it does "occasionally" comes on at lower speeds. Maybe once or twice every 2 weeks.
I've noticed quite a variance in MDS from truck to truck. A family member has a 20' Limited thats optioned very close to my 23' Laramie. Both Hemi, 4x4, 3.92, 5'7" bed & very close payloads. The 20' will hold 70mph with "eco" on & got a hand calculated average of 19.5 & a bit over 20mpg over two tanks on a trip I took with it. I've even noticed "eco" staying on when the current mpg readout showed as low at 18mpg at times. Noticed a buddies 19' Bighorn with 3.92's keeping MDS activated at 70mph too. My 23' at 22,000 miles cant come close to the same. 18mpg is my best tank under ideal conditions while driving in the interest of economy. Most of the time its low 17's, all hand calculated. On my 23', coasting downhill with "eco" on at 70mph & gently applying throttle dropping the current mpg readout slowly, eco turns off once the current mpg readout shows 50mpg. At 55mpg is turn off at 30mpg. Frustrating.
January 11th, just purchased a 2024 RAM1500, Eco rarely comes on, mainly coasting to a stop. Truck seems 3-4mpg under what it should be. My previous two 1500 hemi’s got 18 mpg. 20 at 65mph, 23 at 5mph
So an update on mine. Not sure where or when it happened, but after updating Uconnect, removing pedal commander and swapping the battery, the option for the light to come on was then turned off in settings. After turning it back on, I am getting eco light again. MDS was engaging before just no light even though it was turned on previously in settings.
As far as when it comes on, pretty regularly when I am not in tow/haul mode. Once I reach speed anywhere from 30-65 and during braking. Note that I live in Florida and the only hills we have are overpasses. Also have a CAI, TBS and Corsa exhaust. Not sure if that changes load on the motor or not.
Did you think the pedal commander was worth adding? What did you experience when you where using it?
Have you looked into anything to see where those 3-4 mpg went? I upgraded from a 2011 hemi that would average 18 on 4 lanes. ECO light was on a lot. Now I have the 2021 and average 14 on the 4 lanes and ECO light comes on maybe 4 times on a 3 hour highway trip. EPA of 21 hwy is a huge farce!! Thought i was upgrading to something better with the 2021. Especially with the eight speed tranny. Does feel like the tranny doesn't disengage when slowing down.
2023 Bighorn with 5.7ET and 3.92
My eco mode almost never comes on, while a friend of mine has the 3.27(or whatever it is) rear in his and his eco comes on all the time. I think it has a lot to do with that gearing.
I can also second the banks as a phenomenal device. Takes all of the slop out of the pedal and makes it feel like I actually have a hemi and not a nerfed brick of an engine.
