lasfit lights
Gren71
Delaware
I have lasfit lights to out into my highs / lows / fogs.
Im curious if anyone has had any issues with these lights after install? I leave for a military school in two weeks and will be driving..If i run into an issue I wont be able to fix them while im gone. Any problems with the pcm/bcm or whatever throwing a code? Any reliability issues to report?
I haven’t had any issues with my headlight beams for the 6 months I had them so far. I had an issue with turn signals but they replaced them no questions asked. I did keep my old halogen bulbs just in case I ever ran into an issue.
thanks! thats reassuring for sure. I learned from my JT that the turn signals just werent worth the money to upgrade. I do have the replacement bulbs for the third brake light bulbs...but im probably not going to do those since ive seen a mess of people have an issue with water getting in there and I dont want to create a problem where none exists at the moment.
I have had mine in the HI/LOW, FOG and the wife's car for 2 1/2 year with zero issues. That being said my dad has had a both fogs in his go out in the same time, I firmly believe with him it is more the operator than the equipment but I figured I would include the info anyway
Would you mind telling me what specific Lasfit Part Number you purchased for your Low Beams (H11)? I just purchased their "new" LCair All-in-one series and they will not physically fit into the wiring socket (not the bulb housing).
do you have a picture of what you’re referring to? Do you mean the wiring does not match up for plug and play?
I have lasfit Highs, lows, fog lights, and turn signals. I also did the 3rd brake light with a different brand. I haven't had any problems, although one turn signal came loose in the pass rear housing but it was a simple take it out and reset it.
A few times in the summer the front turn signal has gone out due to overheating, so I don't sit with the blinkers on at traffic lights anymore. Otherwise no issues yet. I have had them in almost 2 years.
I have alla lighting reverse lights
lasfit everywhere else
