i mean if you don't have access or ability to take the shock off then yeap it's easier but you run the chance of messing it up even with lubricant.Correct. But this is quicker and easier, just have to jack up the truck and lube the threads to dial in the ride height.
but if you have the ability to take the shock off then it's always better to take it off and do it with spring compressor so you have zero chance of ruining the threads. seen customers ruining their shocks because they tried to do it with spring tension on the preload adjustor using the adjustment tool lol
Is this knob needed to adjust the high speed to max because it gets harder to turn after a certain amount of clicks? I am getting my BDS 6 in with the Fox 2.5 Performance elite with DSC installed on the 18th and wanted to grab this tool if needed.Thanks man! I’m definitely getting that adjuster knob haha the high speed adjuster feels like it’s welded in place![]()
You need to start date-stamping these pics before some jealous person comes around and starts accusing you of re-posting stuff.And the actual billet preload adjuster tool. The little adapter is a pita to use. It’s worth the $50
But I washed the mud and salt off just for the forum![]()
Dude the high speed adjustment knob feels like it’s welded shutIs this knob needed to adjust the high speed to max because it gets harder to turn after a certain amount of clicks? I am getting my BDS 6 in with the Fox 2.5 Performance elite with DSC installed on the 18th and wanted to grab this tool if needed.
I considered asking for a current newspaper to be held in the picture - for that exact reasonYou need to start date-stamping these pics before some jealous person comes around and starts accusing you of re-posting stuff.![]()
The Fox YouTube tutorials make it seemDude the high speed adjustment knob feels like it’s welded shutI seriously can’t turn it even one click lmao so I’d say this knob would be beneficial for sure
					firemaplegear.com
Well I’m a few days late, but Santa dropped these offafter a couple custom touches to match my truck’s theme, I’ll be throwing them on. I helped install a set of 2.5” Kings last month and they handle everything pretty great - although maybe a little stiff for me. These Fox coilovers for the BDS 6” lift run a 2” longer coil with a lighter rate than the Kings and feature Dual Speed Adjusters instead of a single mid speed adjuster on the Kings. Plus I’ve heard Fox’s baseline tuning is a bit more plush than King’s for these trucks. So hopefully that means I’ll love these shocks! I’m still going to call around to professional shock tuning shops to see if they’d recommend any revalving or swapping coils to get maximum ride quality and performance before I install them. I wanted these for so long I rather pay a tiny bit extra to ensure I get my moneys worth. Buy once cry once hahaView attachment 173713
Lmao don’t hate on my Uggs bro!Dude, amazing shocks but please invest in some slippers, those puppies have no more to give!![]()
FACTSIll take tired slippers over crocks all day every day.
im a sandal/slides type of guyFACTS
So am I but when it’s 40 degrees in the garage I gotta keep these piggies warm lolim a sandal/slides type of guy![]()
You have the Eibach coilovers? If so were they the same overall length as the OEM strut? I'm worried about extra travel when in full droop stressing the upper ball jointAnd the actual billet preload adjuster tool. The little adapter is a pita to use. It’s worth the $50
