One click access to backup camera from home screen?
nimbus
I recently traded my 2020 for a 2022. In my 2020 with UConnect 4, I was able to drag the backup camera icon to the bottom menu bar so I could access it anytime. It doesn't look like this is possible with UConnect 5. Is there any way I can get my backup camera to appear more quickly than having to go to Vehicle > Controls > Rear View Camera every time?
djevox
VP of Creative Thinking
MD
I don’t know of a way either, but hopefully someone knows. I press that sequence of buttons a few times a day.
Whitty37
Yep...I have my rear camera shortcut up top beside my profile icon. Nice that you can touch it while driving and it gives 10 seconds or so of the rear camera view.
n8zcc
Oakland, Michigan
If your dealer didn't provide you with a hard copy of the Uconnect 5 manual you can download a PDF version from RAM. It is an interesting read that talks about the numerous settings available on the new version 5 system. Look under the section titled "Customizable Menu Bars".
Ya, I know, no one wants to hear about the owners' manual let alone reading it but it may just be worth it this time around.
Kiwiaudio
Ohio
Old thread i know, sorry !
Is there any way to make the backup camera picture bigger on the new 5 system ?
SShadow1974
Yeah, there is a button to switch it to the 1/2 screen view of the backup camera without the surround view. I wish you could change the default camera used when reversing. I don't need, nor want, the surround view unless I choose it. I much much rather have the 1/2 screen view, but without having to hit the screen every time to get it.
Kiwiaudio
Ohio
im with you on this. where is the "button" you refer to ? Maybe it could be moved to an area for quick access ?
SShadow1974
When you shift into reverse, the camera comes up and there are multiple buttons for different camera views, I think it's the 2nd to last one in the row.
moosem
Rhode Island
Well, I learned something new today! I had no clue the menu bar was customizable. I always wished there was a way to turn on the surround cameras without multiple clicks!
Kiwiaudio
Ohio
That's how I make sure I'm in the garage.
Thanks for this, youve given me an idea. My new truck only just fits in the garage - it must be about 6" longer than my 14 was. Im going to draw a line on the floor and pull forward until the rear view camera sees the line. That should work !
Thanks again !
Kiwiaudio
Ohio
This video is only a few weeks old, so its current with software. The guy is very good, quick and smart, which means im pausing, backing up and replaying it a lot :)
He covers about everything and i learned a great deal !
Kiwiaudio
Ohio
This is what i want to do, but the status bar shortcut page that pops up when you hit the two lines below the clock in the status bar (in my 24 it is an arrow instead of two lines) only has the surround camera as a choice. I want the full "Rear" camera. So how do i populate this "status bar shortcut page".
And, before anyone says it, i cannot find this in the manual !
Darksteel165
Massachusetts
The arrow vs 2 lines is just the firmware version.
Firmwares from 2023 and above have the arrow, 2022 has 2 lines.
You can't set the rear camera on the shortcut page because you have 360 degree cameras.
Even if you found the manual it is not linked to your trim or options so it's a good guide, but doesn't handle every option you can have on a Limited or a optioned Laramie.
Thanks again !
My garage door creates a "line" on the concrete that I use when pulling in. With the TazerDT, I have the option enabled to automatically bring up the back up camera when park sensors(front or rear) alert to an object. So I don't have to hit any buttons to get the camera on
Darksteel165
Massachusetts
Doesn't work on my 2022 last time I checked a few months ago.
Kiwiaudio
Ohio
Huh ... ok, thanks Dark. Man, All i want is a nice big rear cam picture and to have it easily accessible - too much to ask i guess.
This Tazer DT that HSKR is talking about seems to maybe allow more programming ability ?
