Hi guys, recently got myself a 2021 RAM 1500 limited and wanted to put the factory tires to rest and what better way to do that if not by doing burnouts! So I did some research online and these are the methods I tried:
Method 1: 2wd, rear axle lock, traction off. Step on the gas and as she begins to move, stomp on the brakes (tried feathering the brake pedal as well). As soon as I press the brake pedal, almost immediately power cuts off to the engine and the driver cluster screen shows "Performance may be limited. Press one pedal at a time" message. No burnout!
Method 2: Pull F26 fuse from engine bay fuse box. 2wd, rear axle lock. Try to do a burnout and the exact same thing happens again and I get the same message.
Anyone know what I could be doing wrong? Is there a way around this?
Any help is appreciated. Thanks!
Note: I'm in the Middle East and the truck is middle east spec as well.
