Tri fold hard cover to short?
Mopar21
I have a rebel with rambox and multi tail gate, I have the Mopar trifold hard bed cover installed by the dealer and seems like the end of the bed cover doesn’t meet up or overlap the tailgate at all. Water gets in, this is my first pick up truck. Is this normal or is it possible they installed it to far up?
Thank you
Also anyone have any ideas for the rambox /tailgate gap?
No issues here, rambox and tri fold cover as well.
I'd check the fit by the cab. It sounds like it's over that end a bit too far.
This isn't my favorite cover by far, but it works. My last three trucks (2 F150s and a non rambox Ram) have had soft roll up covers I was able to get watertight (a bit of caulk in the rail corners sealed it them up nice).
Thank you, is it hard to adjust? And did you do anything to prevent water coming in the gap at the end of the tailgate because of the ram boxes?
I have a LoPro soft rollup - Rambox and MFT - no water gets in. There should be rubber seals at the end of teh tailgate. If not I think somebody in this forum linked where you can buy some that fit the gap exactly.
It's very easy to adjust, the front is held on with two clamps like the rear.
I did not seal mine up.
Here's some options, though.
Or one of these...
The foam seal that came with my BAKFlip was half exposed at cab side and degraded pretty quick due to sun exposure. I would use rubber seals for this application, not foam.
Or one of these...
Thank you. Have you bought from them before? Ramseal?
