Stock ORP 20's uneven wear
ExcursionDiesel
I'm at 6800 miles with the stock 20" Falken AT's on a Limited 4x4 with Off Road Package and the fronts are starting to feel "feathered" on the outside edges. I haven't rotated them but I've never noticed uneven wear this soon on prior vehicles. Is this normal or is my factory alignment off? The truck is driven in Aero ride height (lowest air ride setting) 95% of the time. Not sure if that matters or not.
Thanks.
Running OEM tire pressures?
I assume you mean Falken.
Yes. Falken. I corrected my post. I'm running them at 42 PSI front 4O PSI Rear. Looks like I'm on track to get maybe 25k-30k miles out of them at the rate they are wearing.
i rotate tires @ 5000 mile intervals, 1100 miles from now.
OP, take it to the dealer and have the alignment checked. if anything i'd guess that in Areo mode the insides would wear more that the outside.
have the dealer cycle the air suspension on the alignment rack to see what if any changes occur and post any significant findings.
I'll try try to get by the dealer next week. The feathering is more evenly distributed across the entire tread than I thought. That leads me to believe it's either too much toe or just signs of a needed rotation. Improper toe affects mpg as well since the tires are constantly scrubbing. I'm going to do an old school check with a tape measure tonight.
