FRONT SWAY BAR END LINKS
Detroitmikeb
Just had my truck at service and the sway bar end links went bad on it. I been searching for aftermarket ones with no luck. Does anyone know if they are even available aftermarket ones ?
I know this is so old but what symptoms did you have that made you take it in? I think I might have an issue.
kdoublep
USA
Probably easier to get under there and take a look. Check the bushings. Make sure nothing came detached. Pretty simple look see.
