ayoslickxd
- Feb 7, 2021
rear sryDid you upgrade the front or rear end links??
Please let us know! I may be getting these at the end of the month. Tired of leaning on every highway exit ramp!Just installed the end links from suspension MAXX yesterday. Pretty straight forward install. The front end seems more responsive. Will report back down the road.
Did you trade it in because of the issue?Just got mine back from the dealer they replaced the sway bar and end links. They had actually broken. Trading it in toda
I just put mine on today too and noticed a more firm front end. My plush ride is still there, this just plants the truck more. It’s awesome because I’ve made incremental changes over the last year and the ride just keeps getting better.UPDATE: Got my end links on, the truck drives so much better now that the front sway bar is connected. Haven't had end links for almost 3 months, so can't compare to stock, but the parts are robust and went on fairly easy.
#1 Tip is to get one side in, top bolt first, then bottom bolt, hand tighten nuts, then put on the other side. I re-torqued all nuts after 25 miles and had significant tightening on all pieces, just FYI. I will re-check after 100 miles to see if there loosen anymore.
My lower stud doesn't show any threads either once torqued.I just put mine on today too and noticed a more firm front end. My plush ride is still there, this just plants the truck more. It’s awesome because I’ve made incremental changes over the last year and the ride just keeps getting better.
For those who installed the SuspensionMaxx links, did you notice that there wasn’t a terrible amount of threads showing past the nut where it attaches to the bar and lower control arm? The studs are almost flush with the tightening, and that’s with torquing down to 45 ft lbs.
Threads were the same for me. I believe all x4 bolts were pretty darn flush with the back of the nut when torqued. I got x1-2 turns out of the wrench when re-torqued after the first 20ish miles. This made me worried as it seemed like a lot, so after another 100 more miles I re-torqued again and they had barely moved. I feel confident now that they're set in place and will be re-checked at the next oil change.I just put mine on today too and noticed a more firm front end. My plush ride is still there, this just plants the truck more. It’s awesome because I’ve made incremental changes over the last year and the ride just keeps getting better.
This makes me feel much better….I might crawl under this weekend and just retorque just to make sure they’re tight. But loving the ride with these on. Now to replace the rear.Threads were the same for me. I believe all x4 bolts were pretty darn flush with the back of the nut when torqued. I got x1-2 turns out of the wrench when re-torqued after the first 20ish miles. This made me worried as it seemed like a lot, so after another 100 more miles I re-torqued again and they had barely moved. I feel confident now that they're set in place and will be re-checked at the next oil change.
I kept he rear stock, when I put my Hellwig on. Mainly changed the front as I've been waiting for +6 weeks from the dealership and the last expected delivery of OEM sway bar links was end of June. They'll probably get bumped again just like the last x3 updates they gave me.This makes me feel much better….I might crawl under this weekend and just retorque just to make sure they’re tight. But loving the ride with these on. Now to replace the rear.
Update to this: got my new top links today and threw them on. Went much smoother and put so much goddamn threadlocker on there, so we’ll see how it holds.So this was interesting, and I’m sure this was my fault. I climbed under the front of the truck this evening to check some stuff out and lo and behold, the top bolt for the d/s front end link was completely disconnected from the sway bar.
I have no clue when this could have exactly happened, but my suspicion was a rougher ride on the sand in North Carolina a few weeks back. The nut may have come off, the bolt may not have separated right away.
This was for a pair of SuspensionMaxx front end links. My guess is I just buy a 9/16” nut to fasten it back on? I’ll go with stainless steel because of the elements.
I did have them torqued down,but the top bolts to the sway bar don’t have a lot of thread to tighten down.
UPDATE 7/7: I called SuspensionMaxx this morning and before I could explain the entire story, Larry said he was going to send me a whole new link kit that has been updated. i guess the updated kit includes threadlocker for the upper bolt/nut, so they must have been getting reports of links separating. Its hard to find companies like this anymore, awesome service! So if you had issues with the nuts coming off, put some threadlocker on there.
Did the new links appear to have a longer stud on top or did he literally send you a new kit just to include the thread locker?Update to this: got my new top links today and threw them on. Went much smoother and put so much goddamn threadlocker on there, so we’ll see how it holds.
I torqued the link On the control arm to 60 ft lbs and tried my best to torque down the top link, but the tie rods made it almost impossible to get the torque wrench in there. But I used the ratchet and went gorilla on it.
no, I thought the same thing, but I held the old And new up next to each other and they were exactly the same.Did the new links have a longer stud
