2019 1500. Floppy headlight that can't be adjusted
Merrick2252
Hey folks, this morning I went to adjust my headlights because they're pointed a little high, the passenger side adjustment does seem to do anything but spin, and then I noticed if I reach in and grab my high beam bulb i can tilt the whole assembly up and down and it's very loose. It almost seems like the adjustment screw has come loose from the reflector assembly. Has anyone encountered this before? I don't want to go through a dealership and I'd rather fix it myself if it's possible. Any tips?
Scram1500
The adjuster is broken or off the track. You could try opening the the housing for a repair but that means removing it from the truck and baking it in your oven. Might be easier to get a replacement off eBay
Merrick2252
Looks like that's what I'll be doing. I just feel bad cause I'll be blinding a lot of people in the meantime 😅
