Bamaboy23chris
- May 4, 2023
Hello All,
I have a 2019 Ram 1500 limited. I purchased from dealership in April of 2022 as a Certified used vehicle with 73,511 miles. Truck currently has 133,706 miles. Great truck with no issues, all Maint. done on time and records for that. Truck developed a tick on startup about 5 months ago but would always go away within a min. once heated. While on my way to work that morning the service engine light came on. I stopped to read code which was P0308 (Cylinder 8 misfire). Plugs had been changed at 90k, so I thought this may be a failed plug. I changed the plug and reset the code. Drove about another 50 miles and service engine light came back on. I checked codes again and same error P0308 (Cylinder 8 misfire). I changed the boot with no luck and also redid the 2 plugs in cylinder 8 with no solve. I took the truck to the dealership to be looked at on Oct. 20th. After diagnostics, I was told that I need a new engine, there was an internal engine failure. When I asked how that could be, I was told that there is a known issue with lifters and/or cylinders that fail to switch. My powertrain warranty is over and I am 10k over the extended warranty. I am being told I will have to pay out of pocket near 13k. After researching, seems this is a known common problem with this year model and engine dating back the last several years. I have read about 16 of these issues on this forum alone. Problem for me is buying this ram with a hefty price tag and being told that I have to cover something, that is no fault of mine own as a consumer! How do I get help from RAM to cover expenses? Dealership has reached out but RAM is unwilling to help. Hate to rant, but I still owe 40k on this vehicle and I have only driven 60k miles since owning. Engines should not be failing at 35k - 150k miles! HELP PLEASE! Way to close to Christmas to be dealing with this. RAM has always been my number 1 truck on the market but this has really changed my mind. RAM should want to fix known issues. RAM should want to take care of their customers.
