- Jul 25, 2020
Why wouldn't it?So a 275/65/18 tire will work/fit fine on the steel temporary rim?
YesSo a 275/65/18 tire will work/fit fine on the steel temporary rim?
Everyone gets the same spare unless you get an TRX with that offroad package thing.2022 longhorn I have the aluminum spare truck has 20s
Not true.Everyone gets the same spare unless you get an TRX with that offroad package thing.
Who gets a real spare then?Not true
The ORP group trucks get full size real spare tire. But my spare tire was on a steel wheel. Not 100% sure what option decides if you get the temp spare tire, aluminum wheel, steel wheel, or real full size spare tire, other than the ORG group.Who gets a real spare then?
This was one of the reasons I order the ORP, along with the e-locker, tow hooks, and +1" ride height. Mine came with steel wheel and Falken tire.The ORP group trucks get full size real spare tire. But my spare tire was on a steel wheel. Not 100% sure what option decides if you get the temp spare tire, aluminum wheel, steel wheel, or real full size spare tire, other than the ORG group.
Mine too. 33 inch tire.This was one of the reasons I order the ORP, along with the e-locker, tow hooks, and +1" ride height. Mine came with steel wheel and Falken tire.
If you have 18" wheels from the factory, then yes. The spare tire wheel is 18". If you have factory 20" wheels, you will have to find an equivalent outside diameter tire for the 18" spare, ore buy a matching 20" wheel. I have a matching 20" Built to Serve wheel with a 34" tire on it under my bedhavent finished the thread but figured id ask anyway...
will an OEM tire fit on the spare rim AND in the space tire space?
Ill be replacing my ires soon (hopefully) id would HATE to get stuck changing into this limp spare while im pulling my camper.
I understand that, but is that 18" rim wrapped in a tire that has the same diameter of a 275/55/20? Because if it doesn't, running that spare is going to cause issues with the speed sensors because that wheel will not spin at the same speed as the rest of your wheels... Which basically makes that spare useless.You always get the same spare unless you get the ORG or a TRX. Even my Limited with 22s came with an 18 inch painted aluminum spare.
Yes, the spare should have a tire equivalent to the diameter of whatever the regular tires are.I understand that, but is that 18" rim wrapped in a tire that has the same diameter of a 275/55/20? Because if it doesn't, running that spare is going to cause issues with the speed sensors because that wheel will not spin at the same speed as the rest of your wheels... Which basically makes that spare useless.
Not only will the spare not be the correct size, if you take it out and look at it, it has temp threads. It's not even a regular tire. I believe it's rated for 55mpg top and 50 miles of use before it's trash.I understand that, but is that 18" rim wrapped in a tire that has the same diameter of a 275/55/20? Because if it doesn't, running that spare is going to cause issues with the speed sensors because that wheel will not spin at the same speed as the rest of your wheels... Which basically makes that spare useless.
It will fit your truck, it's just a differnet size wheel is all. For temp use it's 100% fine.I ordered my 2024 Laramie G/T with the $0 optional 5-spoke 20x9" wheels and 275/55R20 Bridgestone Deuler H/Ls.
My spare is an aluminum 18x7.5" 12-spoke wheel with a 245/70R18 GoodYear Radial Spare..looks like half tread.
A quick Giggle search shows this tire has 5/32 tread and 31.5" height.
I imagine this aluminum wheel wouldn't have any issues with the OEM lugs.
thanks! I do have the 18in rims and im looking at a take off spare tire from craigslist for $50 to swap onto the spare rim so its useful if im stranded while towing.If you have 18" wheels from the factory, then yes. The spare tire wheel is 18". If you have factory 20" wheels, you will have to find an equivalent outside diameter tire for the 18" spare, ore buy a matching 20" wheel. I have a matching 20" Built to Serve wheel with a 34" tire on it under my bed
