Running switches for accessories
CalamisC
Sorry if this is a true newbie question, however I am a newbie :) Looking to install a light bar on my 2022 1500 Bighorn. Is there a method that is generally followed where drilling is not needed through firewall to feed a switch line to turn the bar on and off ? I am preferring to use a standalone switch to control the bar, not tie it in with any other function
thank you
There's a large grommet right above brake pedal you can pass a wire through.
Sent from my SM-S918U1 using Tapatalk
If you plan on running multiple accessories in the future, might as well install something like the Trigger 6 shooter.
I'll save you some searching.
I had the same train of thought. Ordered set of 3 homelink garage door control modules with remotes, each controlling 3 modules. Hooked them up to a 12vdc power supply and programed the remotes for 1st push on, 2nd push off. Next step was to take one of the remotes to the truck and program the garage door switches on the visor. Instructions are in the truck user guide. Done. Now I have 3 remote controlled relays that I can interface to outdoor lighting, or truck add ons.
I used this and the install couldn’t be easier!
I’ve had it for 1 year and some change and it’s been flawless.
