Rear window leak
mikeru82
The Palouse
Thanks for the pic. I wondered exactly where it's mounted on the back wall but haven't had time or motivation to take our truck apart LOL.
Kaldir1934
My truck goes in December 4th for a water leak test. Rear glass was already replaced a year ago, and it's leaking already, so hopefully after it fails this new water leak test and it gets replaced again, it will stay fixed. (I doubt it though)
6of36
Michigan
They are using a new design since June.
St-na
Houston
Received 2 letters from FCA, they have extended warranty for the window and CHMSL.
irishwake63
I got confused when the other poster said it was under the vents. I did put a piece of gorilla tape acting as flashing over the large box in case it did leak on it it would hopefully roll off. I do have a tiny amount of water running down the drivers side corner not soaking the headliner or floor so hope its not too bad
kapinallinen2
5thGenRams Supporter
Southern Maryland.
My frame was cracked in the corner, causing a similar leak.
kapinallinen2
Southern Maryland.
you are talking the window frame? or the body frame as I dont see a frame do I have to remove the headliner?
Rear window frame.
Post from about a year ago.
Rear window was replaced 1-6-2020 under warranty.
It has now developed the usual crack next to the slider, not all the way thru to the outside yet so no leak there.
But is is leaking alright...
Took some effort to find this (soapy water and positive pressure did not pinpoint it, due to operator error mainly)
Anyway, upper drivers side corner, have not seen anyone reporting this location for a crack so far.
Attachments​
