RAM Patriot
Has anyone tried this upgrade on your rear coils?
I agree, if you need that kind of suspension on your truck you should probably look at purchasing a 2500.I would think that heavier springs would make the truck ride rougher without a load. The Timbren suspension only works if the truck is loaded. I have used air bags in the past but they are a hassle because you have to make sure that they have the correct pressure.
Exactly, springs or Timbren will not increase the load capacity.I agree, if you need that kind of suspension on your truck you should probably look at purchasing a 2500.
I don't think most people are looking to actually increase payload, just handle even half the rated payload without excessive squat etc...Exactly, springs or Timbren will not increase the load capacity.
