paulmarsh22
- Dec 10, 2020
I've said it before but man that's a beautiful build. I have my 37x13.5r22 Ridge grapplers coming in a couple weeks. I finally found a local 5th gen on a 6" lift with 22x12 -44 and 37s and he made it work with minor pinch weld trimming so I finally pulled the trigger. I'm on a 5" lift for the air ride plus revel links for that extra inch. Thinking on adding that 2" body lift to clear 37s and wide offset with no trimming at all but we'll see how it looks with the current setup and 37s first.I was on 35s from Jan 2020 to July 21 and then 37s since then until now - so a little over two years. I don’t beat my truck off road like some people, but I do take it out on the trails and have fun! My truck is on a BDS lift and basically set up 1” lower up front and 2” lower in the rear than most 6” kits and I still clear the 37x13.50 Toyo MT tires just fine with 18x9 -12 offset. Those tires are actually 14.2 wide too. I was actually supposed to get 38s this week but they became backordered again so instead of doing 38s I may add 19mm wheel adapters instead to push out the stance a bit & it’ll be insanely close to the bumper but still no bumper trimming and only mild pinch weld trimming. As far as breaking stuff with 37s I haven’t had any issues aside from wearing the tie rod ends out at 32k miles. Pretty cheap $150 fix though. 35s perform much better on these trucks but the 37s look infinitely better. Plain and simple. After having 37s (and getting used to how the truck behaves with them) I can’t imagine ever going back haha
Are you gonna post on IG when that lower grill kit is available for sale? I think it looks much better than a light bar.
