Learned something new.
Marine6212
Learned today that my '23 ram tradesman turns the hazard lights on and honks the horn when you are airing up the tires when the low tire pressure light is on.
It’s an option you can turn on/off in Uconnect (Tire Fill Alert).
Let's you know it's full huh?
I just put air in my tires today, the system never works right.
Honked on the first tire, and on the 4th tire, on the 4th hazards turned on too lol.
It never seems to honk all the time.
I did get the 3 honks (even with the Tazer) today too with the engine not even turned on, just the battery.
I think the truck needs to be driven for a bit to get the system to work right. I filled mine up yesterday before I left for work, and I got my rear tire to 54 PSI before it honked at me. I noticed it wasn't honking at the right pressure so I just let it go until it did.
I use an old fashioned tire pressure gage. It never failed me once.
Nothing more irritating than my truck beeping at me.
Yep.
The 4th tire it honked at me AFTER I disconnected it and walked around the other side of the truck with the air compressor in my hand.
Yep.
Very weird, having prepped many new cars with the system I haven't had any not work.
It never has properly for me.
Maybe it has something to do with recommended pressure. My truck came with 22s and door jamb says 36 PSI. I pumped up to 38 and still no honk, inconsistently.
