Bonafide823
- Dec 16, 2018
Thats the route I want to go withHere’s my Mopar hard top! Can’t beat it!
I want to get the mopar folding one but I wanted to know how it does with rain? Does it get through? Also, are mopar products covered on a mopar lifetime warranty? Just curious.
This is the Mopar hard trifold installed on my truck, ignore the masking tape.
View attachment 11938View attachment 11937
I am considering getting this cover myself. It looks really nice! How do you like it so far? Are the panels on this cover like a power coated aluminum? Also if you need to take it completely off for full bed access how heavy is it?This is the Mopar hard trifold installed on my truck, ignore the masking tape.
With this cover you have 95% bed access it folds against the rear window, if you wanted to remove it completely probably a 30 minute job, the unit weighs about 30-40 pounds. yes powder coated aluminum. I like it however I get water in at the corners and some on the sides it runs down the walls and out the truck, still more than I've typically seen with this type of cover. Lastly just like everything else in this truck QC bad right rail took alot of effort to install, left I pushed in by hand with 0 effort.I am considering getting this cover myself. It looks really nice! How do you like it so far? Are the panels on this cover like a power coated aluminum? Also if you need to take it completely off for full bed access how heavy is it?
Is the factory cover easy to fold back and how easy is it to remove if you need the bed space? My brother in law has a Bakflip on his 2017 Laramie and that seems similar to the Mopar version. I have heard they are the same but not sure if that is true.This is the Mopar hard trifold installed on my truck, ignore the masking tape.
Any problems opening and closing the tailgate with the cover down? What about power assist tailgate? Thanks in advance man, love the truck.Gator SFX soft tri-fold ~ paid $219 shipped
tight seal, simple install, perfect fit, well madeView attachment 11775View attachment 11776View attachment 11777
noneAny problems opening/closing tailgate with the cover down?
How hard is it to remove completely in the instance I need to use the whole bed for furniture or something of the sort.none![]()
It's exactly the same cover bak makes them for Mopar. The mx4 is matte, the G2 and Mopar are gloss.Is the factory cover easy to fold back and how easy is it to remove if you need the bed space? My brother in law has a Bakflip on his 2017 Laramie and that seems similar to the Mopar version. I have heard they are the same but not sure if that is true.
it exactly the same as the Mopar one is made by BAKIs the factory cover easy to fold back and how easy is it to remove if you need the bed space? My brother in law has a Bakflip on his 2017 Laramie and that seems similar to the Mopar version. I have heard they are the same but not sure if that is true.
