racterman
- May 16, 2021
Hi guys! I'm having a lot electrical issues with my 2019 Big horn. The first thing that happened was a death battery that i replaced right away. My truck was running like a charm for a few month until it won't start at all just clicking. At this stage i did a battery test, it was under 12 v but in good shape so i started troubleshooting the issue and i found a couple of fuses out into the interior fuse box and into the high current fuse array the N6 300 amp fuse blow up too. i just ordered the high current fuse array in mopar store and replaced the rest of fuses but before to put the truck running i would like to know what can cause this kind of problem because may be there is other component compromised. there is almost no information about 5th gen of Ram and its hard to know how their systems work. But i found that the N6 fuse is related with the Power Package Unit (PPU) but my model isn't E-Torque so right now I'm lost. Right now the battery light is on and it won't charge the battery (i forgot mention that i had replaced the alternator as well) If some of you have some similar experience or had o some information about this issue pls help!
