Common Issues and Air Conditioning
If it is hot outside, I have the A/C on, and I stop at a red light the auto-stop will only engage if the cab is at the set temperature. Otherwise the truck will continue to run. If auto-stop has engaged but the cab temperature climbs above the threashold, I have seen my engine restart so that the A/C can continue running.
As an aside, I was getting a deeper exhaust sound. Since I was going in for a free oil change, I had the dealer look. There was a broken exhaust bolt but not at the header, but further down the line somewhere. I'm going today to pick it up and find out where the broken bolt is. However, since I am beyond the 3yr/36k warranty it is not covered. It is also not covered by the extended warranty because it is not a mechanical part and the entire exhaust is excluded as a "consumable" part. They wanted $550 to fix a bolt. 😤
I also had an unsual sound out of my A/C, so they determined that the blower motor was failing. Covered under the extended warranty.
My 2021 Bighorn is a hair under 50k miles.
It's probably the connection right before the muffler. Common issue. I need to get some stainless steel bits to replace mine. They rust out and break. Especially if you never wash the undercarriage of the truck. And auto car washes don't count
BoxerguyT89
I broke this bolt on mine and replaced them both with stainless. Took about 10 minutes to extract the old broken one and install the new ones.
DEG
Yes, that seems to be the way mine works as well. Until it reaches that threshold for restart the temperature change is noticeable though not unbearable. I only notice it on 100 degree days. I suspect at lower outside temperatures the cabin temp does not climb fast enough to notice during the duration of a typical traffic light.
Quint
Minnesnowta
That's exactly what it was, the connection just before the muffler.
steveved
Cary, NC
FYI... The heater core on my 2019 went at 77k miles. Was a $1600 repair job. Everything else works fine. Oh, and my stock battery died after 2.5 years. Replaced it with an Interstate.
NightRam2020
AC works good. If you have a sunroof expect it to be significantly hotter even with it closed. Also ventliatd seats are terrible.
2020 Laramie CC 5.7l etorque 4x4 45k Miles. Ventilated seats work great for me. A/C in the New England summer worked just fine.
Houstontiger
A/C in a 22 Ram 1500 is good but not the best IMO especially here in Houston summer days. There's also an annoying consistent AC condensation at bottom of the windshield.
6of36
Michigan
In the old days, 5 years, and 77,000 miles, it would be in the junk yard. That's not unreasonable to go bad. They all need a new battery at 3 years. At 2 1/2 it should have been warranty, unless you were over miles.
What are you calling the "old days"? Maybe 80's cars. Even go as far as early 90s.
theblet
I test drove the Grand Touring yesterday. I found the air conditioning to be somewhat underpowered. I live in Florida and am a bit concerned. Any others experiencing the same issue or having difficulty cooling the car quickly?
No issues with mine since I got the TSB. It works well, but still not as good as other vehicles I’ve owned. My Kia optima A/C is like a fridge.
