If it is hot outside, I have the A/C on, and I stop at a red light the auto-stop will only engage if the cab is at the set temperature. Otherwise the truck will continue to run. If auto-stop has engaged but the cab temperature climbs above the threashold, I have seen my engine restart so that the A/C can continue running.
As an aside, I was getting a deeper exhaust sound. Since I was going in for a free oil change, I had the dealer look. There is a broken exhaust bolt further down the line somewhere from the header (apparently not due to rust). I'm going today to pick it up and find out where the broken bolt is. However, since I am beyond the 3yr/36k warranty it is not covered. It is also not covered by the extended warranty because it is not a mechanical part and the entire exhaust is excluded as a "consumable" part. They wanted $550 to fix a bolt.
I also had an unsual sound out of my A/C, so they determined that the blower motor was failing. Covered under the extended warranty.
My 2021 Bighorn is a hair under 50k miles.
