Weird goings on
UnclJim
Long Island
Been having an issue for a couple weeks now.
Turn truck off and I get a pop in speakers if radio isnt' shut off. Sometimes the truck will go dead upon shutting off, open close reopen door and truck is alive again. On a rare occassion truck will be dead in the morning i will need to open it with key and after a minute or so it come alive and alarm goes off. Also I will need to reset climate pre settings, as well as turn fogs back on after most shut offs . Also surround sound will be turned to off.
Truck still has driver presets as well as remembers my cell phone. Any ideas?
vincentw56
Maybe get a new battery. Or have yours tested. Or just get a new, better one.
kapinallinen2
5thGenRams Supporter
Southern Maryland.
RF hub got wet from leaking rear window frame?
HemiDude
Ohio
I see in your sig that you have added a lot of electrical goodies, any chance your problem coincided with the the timing of one of those? Outside if that, I would suggest checking for loose connections at the fuse box in the engine compartment, as well as the ground connections at the frame.
UnclJim
Long Island
everything runs independent of the electrical system of the truck.
UnclJim
Long Island
It ended up being the ground connection there was an odd upward slant to the battery post I had to get small lead shims to put in at top of terminal connection to keep terminal from walking up.
Thanks all for the input!!
6of36
Michigan
Yep. Bad grounds are common and troublesome.
