2019 ram limited 1500 5.7 hemi spark plugs
Doug@77
I have a miss fire in cylinder 6. Truck has 80523 miles on it . Purchase it use. What's the best spark plugs to use that will last the longest before need replacing. 2019 limited 5.7 hemi 1500 . I got a rough idle no check engine light
Could be the plugs, coil pack, injector or slightly stale fuel ,ask me how I know about the fuel...
You don`t have that many miles on it, I would run with Lucas injector cleaner in the tank for a week and see if it clears.
Could be. Although, I will say. I had a coil pack and injector go bad at 59k on my truck. Rare, but **** does happen sometimes.
I'm only at 6k and my cyl 5 coil pack is intermittently cutting out and running rough, stumbling when it's hot. Dealer ordered a new one and will get it swapped out. Previous last vehicle, I also had a bad coil pack on cyl 6 at around 15k and it now has 115k on it without any further issues. Vehicle before that never had a coil issues. I'm not concerned over little electronic failures like this...it's normal.
