7 way plug in bed
ameyer81
Hey folks, I searched but didn't find any discussion about this topic.
Has anyone installed 7 way plug in their 1500 bed? I'd like to plug into a 7 way there and it would be cleaner than running the down the the factory location next to license plate.
How did you do it? Where did you tie into the stock wiring? Which OEM or aftermarket part #s did you use?
Thanks in advance.
What are you towing that needs a 7 pin in the bed? Most trailers we 1500 owners tow are receiver hitch capable
My installation starts in #6
It's a preference of plugging 7 pin into the inside of truck for a 400lb snowmobile deck, which has reverse lights and the lighting assembly is better run through a 7 pin for that reason. Also better than running it under the tailgate to the exterior to catch road spray all winter.
