Air Suspension Issue CODE: C151-E11
Richkey85
Hi Guys,
Just wondering if anyone else has had the service air suspension show up, I read the code C151E-11 which is: 1679680516093.png
Im from Cananda so we do have alot of road salt, however I took apart the connector, no issues went over the harness it was good, I ordered a new sesnor Im just waiting for my loacal dealer to get the part in. I changed the battery just incase that was it and is was not, has anyone ran into this issue? if so what was the fix?
First one of those that I remember reading about.
The sensor being faulty is a good possibility if the harness looks good.
It could also be a bad ASCM.
Post an update when you figure it out.
@Richkey85 what was / finally fixed the issue ? Currently running through the same thing on a 17’ Limited . Thanks
I had the front right sensor brake off at the base so I just decided to switch out the left sensor at the same time if it was faulty, no codes popping like it did before . Thanks
