Limited Dash Delamination
Limited Legend
Michigan City, IN
Out cleaning my truck, noticed the leather on both sides of the center speaker has 2 bubbles. Is this how the delamination starts for those of you who have had this issue? I AM STILL UNDER FACTORY WARRANTY. When I push on the small humps it's raised up. I believe it's starting to separate. Pics posted for your thoughts. Thanks everyone!
Limited Legend
Michigan City, IN
The pic on the right is hard to see, but the seam is loose from the dash. The pic with my with my finger you can see the small mound to the left of my finger.
6of36
Michigan
Your new post is probably the fourth or fifth on the subject now. Common problem. Just get it fixed while under warranty.
BlkLimited22s
I had a large bubble ~4" by 4" on the passenger side between the center console and airbag. They replaced under warranty but new dash didnt fit right at the gauge surround, so they had to replace the gauge surround also.
mikeru82
The Palouse
As mentioned the factory warranty will cover this. Make sure you take care of it while your warranty is in effect because it won't be covered by any aftermarket warranty.
FastBlackRam
Yours is hard to see and looks so minor at this point. I would be surprised if they gave you a whole new dash for this. But I hope they do. You may want to wait until it gets worse if you have time. which it likely will.
Mine bubbled up more with summer heat during the day but would shrink and be barely noticeable after sitting overnight in the garage. It did eventually get so bad that it was bubbled all the time. And large areas. My delamination started as smaller bubbles but was much worse than yours even at the beginning. Under warranty they replaced my entire dash. It came out looking like new, no rattles or squeaks. I did use Mopar cleaner on it before it started to delaminate thinking it was safe. I never told the dealer, but I think it may have caused the problem since it was widespread on my whole dash eventually. The dealer did ask me if I ever used any cleaners on the dash but I told them no. Now I only wipe it down with a damp shammy and the new one has held up perfectly.
