2024 1500 Tradesman Warlock vs Off Road packages
EEnginerd
Does anyone know the difference between the Extra Heavy Duty Shock Absorbers on the Off Road package vs the Performance Tuned Shock Absorbers on the Warlock package on the 2024 RAM 1500 Tradesman?
considering that both options give you the raised height I am gonna assumed they are using the same shocks just worded differently in the package
maybe somebody else with more concrete info will share some feedback
Figured as much, but seems strange it would be worded that differently.
I'm not sure you can assume that they're the same shocks based on that reasoning. Don't they use longer springs for the additional height? But it seems to me that it would make sense for them to use the same shocks for both packages.
I would guess that performance tuned shocks might be bilsteins like on the Rebel.
correct it is the springs that give the raised height and that is why it makes sense to me as well that they would use the same shocks for both.
that would be good but I have ever only seen Bilstein's on the rebels, not big horn or tradesman - but I can't speak on Laramie's
